ES300 HID to Halogen Posted May 26, 2020 Share Posted May 26, 2020 I have a 2003 ES 300 that came with factory HID low beams. Although I love HIDs i have had nothing but problems with them and i am tired of spending 70 bucks a pop on bulbs. Is there a way to convert from HID to conventional halogen bulbs so i can then in turn upgrade to LED? Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted May 26, 2020 Share Posted May 26, 2020 How often are you having to buy HID bulbs? Are you buying new high quality OEM 4100K HID bulbs? Stay away from high kevin off-brand bulbs. I've never had an OEM HID bulb burn out. My 2000 LS400 was still on its original factory installed HID bulbs when I sold it in 2014. The HID bulbs in my 2014 Toyota Sienna Limited van are still the original ones. You would have to replace your current HID headlight units with the standard units in order to use low beam halogen bulbs and also do a considerable amount of inventive re-wiring. You would also lose the automatic beam leveling feature. LED headlight conversion kits are mostly crap. Quote Link to comment Share on other sites More sharing options...
