i recently changed three of the four door lock activators on our RX300
the rear door on the passenger side will not open with either the outside or inside
door handle.
the front passenger and rear drivers side work perfectly although i cannot open them with key fob.
where is the sensor for the key fob located and is there a fuse?
Fuse functions are shown in section 6-4 of the 2003 RX300 owners manual.  There appear to be multiple fuses for the door locks.  Here is a link to the owners manual in the Owners section of the Lexus website:  https://drivers.lexus.com/t3Portal/document/om-s/OM48442U/pdf/OM48442U.pdf
It looks from the parts diagram that the receiver for the wireless door lock system is in the left rear fender - image of diagram attached.  Sorry, I had to reduce the resolution substantially when snagging the image to get it to fit on my screen but you should be able to zoom in on it.
