Guerrero Joe X Gotti Posted August 26, 2019 Posted August 26, 2019 hello I have a 99 lexus rx300 i changed the battery and went to try and start it I put in the key and the dashboard does not move turn the key to start it and nothing happened it's not the starter I hot wired it n it started up I tested the wire to the starter and it's getting no power also my headlights are out the turn signal works no high or low beams I've tried to reset trick locking n unlocking from outside then use the key fob and still nothing any assistance would help
jjbrahma Posted August 26, 2019 Posted August 26, 2019 Hello, I just saw your post and went looking for a solution. I have found many solutions to a Lexus problem on other non-Lexus sites. That being said, I found the following site, and the problems discussed seem very similar to yours. https://ls1tech.com/forums/general-maintenance-repairs/491898-car-won-t-start-battery-fine-no-gauges.html Take a look at the postings on the 1st page and you'll see at least one post like yours. Hope this helps. Good Luck!
