SC430 "VSC-VSC OFF" Lamp Reset
Paul Cook
This worked for me.聽馃榾
1. Tools - paperclip聽
2. Photo of where to install the paperclip.聽
3. Car parked on flat level surface with steering wheel turned to the straight position.聽
4. Insert key in ignition but leave "OFF".
5. Insert the paperclip in the White OBD II Port connector position shown in the photo. (located under the dash by the drivers left knee. May have a black cover.)聽
6. Turn key to "ON" position (but do not start) and observe the VSC and ABS Lamps flashing on the cluster. Wait 15 seconds.
7. Turn key to "OFF".
8. Remove the paperclip from The "White OBD" connector聽and replace the black cover.
9. Start the car. VSC and the VSC OFF Lamps should be "OFF".
10. Press the "VSC OFF" Button on the center console. Verify "VSC OFF" illuminates. Press again and verify the VSC OFF Lamp on the cluster聽goes "OFF".
Hope this helps someone.聽
Paul
  • Thanks 1
  • 3 years later...
  • 1 year later...
  • 4 months later...
In your pic you show in the OBD PORT the clip in the 3rd top hole and the clip in the 4th hole (is this correct)? It鈥檚 not worked for me? Please let me know as it鈥檚 annoying with the VSC light on all the time.
thanks,
ken
聽 Pasted as rich text. 聽聽Paste as plain text instead
聽 Only 75 emoji are allowed.
聽 Your link has been automatically embedded. 聽聽Display as a link instead
聽 Your previous content has been restored. 聽聽Clear editor
聽 You cannot paste images directly. Upload or insert images from URL.
