Changing Tail Light Bulbs
I have a light burned out on the left rear of the car (2000 ES300). Thought it would be a five minute job to remove and replace the bulb. That was until I encountered the plastic cover inside the trunk that must be removed to get to the bulbs. The cover is fastened with some sort of plastic fastener that I am not familiar with....tried a couple of tools but I'm afraid I'll break off the things if I use brute force. There must be an easy and correct way to get this thing off. Any help will be greatly appreciated.
Use a flathead to pry out the (2) plastic pin-style screws. If you do it carefully, the screws won't break and will pop out pretty easily. If you happen to break one, you can purchase more at your local Lexus parts dept for chump change. Once you remove the screws, pull down the entire plastic cover, and the light bulbs for the driver side tailight should be revealed, like this in my '01 ES:
  • 5 years later...
Just did my tail lights for my dad's 96 es300. Thanks to this rooms help! Who would think it would be this involved. But I did find a few things that were not that well explained, so here is my experience on HOW TOO...
1. Open trunk duh...as one guy said...then clean it out. Another said you don't have to clean it out...well it depends on how much stuff is in there! As you work...I put everything on top of the CD changer for safe keeping.
2. PLASTIC TRUNK CAP COVER: Controversy here on the plastic that runs over the top of the trunk deck to remove or not. I discovered that it does not need to be completely pulled off. But you do have to pop the ends up on each side to get to a plastic Phillips head screw looking plug holding the top of the carpet. A bit scary but it will pop up with a steady pull.
3. PLASTIC "SCREWS": The plastic plugs in the carpet on the trunk deck (that you have to take down to get to the bulbs) are a trip. They look like a Phillips screw with a compression ring. THEY ARE NOT! You can take a Phillips screw driver and give them a 1/4 turn that seems to loosen them but turning any more is a waist of time. Once it comes loose a bit take a regular driver and carefully pry the "screw" out... you will find it is a plug with a flared end with the Phillips head on the other. The "compression ring" part has a four prong pieces that swells when the "screw" piece is pushed into it. It is really hard to remove or install with it all together. When replacing push the "compression" ring part in first then push in the "screw" part. You will find 3 of these on the top of the carpet. On the bottom is two plastic caps at either end. They just pull off and snap back on.
4. TRUNK LIGHT: The trunk light on mine had two prongs to snap it into the body. Someone must have been there before because one was busted off so I can't really tell you how it comes out because once the carpet was lose it came down with the carpet. The clips are on right/left/center so you might be able to push one with a small screw driver if it is stuck and won't move. Other wise you will probably brake it like mine was. I'm still working to put the lens cover back on!
5. BOLTS: 2 on each side are under the side flap of carpeting...just pull it out and look behind it...you will see them. I found 5 nuts on each side. Four 8mm and one 10mm each. The thread part is screwed securely into the light assembly. I had no problem using an open end wrench(s) to get at them. 1/4 turn and the nuts spun off by hand. Gently push on the thread parts to make the tail light move and ease it out. There is a plastic clip holding the wires and it is easy to pull it free allowing you to lift the assembly up to the top of the trunk deck to work on it. Nice if you have 4 hands but not necessary.
6. BULB SOCKETS: All the sockets take a 1/4 turn and pull out. They only go in and out one way so that is easy. Push twist the light bulbs out and in. You will need 4-168's 4-1156 4-1157 to do both sides. Obviously replace them as they come out so as not to mess up like one guy did forcing an 1156 in a 1157 hole. Not a good thing to do.
Anyway...thanks to the room here it was not as bad as I thought it would be!
I found that if it is the screw and compression ring type...take the center screw out first then the ring part. Pulling them together brakes it.
