DeweyGirl Posted July 19, 2018 Share Posted July 19, 2018 I cannot change my temperature on the driver's side from 65 degrees with the ac or heat on. I have tried with and without dual control on just to make sure, and it will not budge. Do I need to buy the entire climate control panel or could it be something else. The passenger side works fine. Quote Link to comment Share on other sites More sharing options...
Heath.dewayne@gmail.com Posted September 11, 2020 Share Posted September 11, 2020 I have the exact same problem with the drivers side temperature controls. How did you get yours fixed? On 7/19/2018 at 2:56 PM, DeweyGirl said: ever Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted September 12, 2020 Share Posted September 12, 2020 The OP hasn't logged on to this forum since July 19, 2018. There are too many components involved to guess the cause of the problem. I suggest that you have a competent technician diagnose it. The repair manual for the SC430 should have a detailed step-by-step diagnosis procedure. Quote Link to comment Share on other sites More sharing options...
