My A/C light flash then no cold air. The belt is tight and the a/c is full of freon. It only flash after driving 30 minutes. Any ideals?
Thanks!
How do you know it's fully charged?  Unless you've put a set of manifold gauges on the system you have no way of knowing what the real story is.  Sounds like a pressure sensing switch is causing the unit to trip out but you gotta put some gauges on it to know for sure.
I saw the a/c guy tune it up with freon.  When the engine is cold, no problem. It only flashes after driving 30 minutes of driving.
You may want to think about taking it back to him if you're comfortable with his ability to troubleshoot the system.  This is going to require a level of expertise above shade tree.  Good luck and let us know what the problem was.
