alexwittmer1 Posted February 22, 2018 Posted February 22, 2018 Anyone aware of a tire for the AWD Is250 that is good for the negative camber they have? Put new tires on in September 17' with an alignment, and fronts are worn on inside and choppy in the center. Was told i need to find a tire good for cars with negative camber... Any insight would be great
alexwittmer1 Posted February 22, 2018 Author Posted February 22, 2018 I should add, I have less than 10K miles on the tires. Also re-checked alignment after the tire wear was noticed
TOPENDMS Posted October 28, 2018 Posted October 28, 2018 It's actually a dynamic toe issue. Every Is has it. The front is due to a soft front control arm bushing from the factory. You can replace with a stiffer unit from the GSF, or a racing type from FIGs or RRRacing. Also because F Sport has a staggered tire setup, you will only get 1/2 of the advertised tire life. So get tires with 40-50,000 miles you can expect 20-25,000. You will get a lot less if you don't replace the bushing.
