jerryparks Posted September 7, 2017 Share Posted September 7, 2017 I just changed the alternator on my 92 LS400. The next day, the car started to stumble on start up. It only lasts for approx. a minute. Did I possibly forget to re-connect something? Is there a cold start item on the car that I need to check? Where is it located? Thanks ! Quote Link to comment Share on other sites More sharing options...
vissine Posted September 20, 2017 Share Posted September 20, 2017 What can you forget? You only need to remove 1 wire at the terminal B post, a connector that has 3 wires on. Unless you broke some other cables when taking it out of its position, I don't think you can forget stuffs replacing the alternator. Or maybe the connector was not pushed all the way. Did you hear a click when you push the connector back in. One other question is: did you check if the alternator perform well after install? It happened to me that I have to return the unit because it was defected. Quote Link to comment Share on other sites More sharing options...
jerryparks Posted September 22, 2017 Author Share Posted September 22, 2017 Yes, the alternator is working great. I have a one extra question. Where is the fuel filter on these cars? I can not see it, even with a flashlight. I want to change the filter as this could be my problem Thanks for your comment Quote Link to comment Share on other sites More sharing options...
vissine Posted September 22, 2017 Share Posted September 22, 2017 27 minutes ago, jerryparks said: Yes, the alternator is working great. I have a one extra question. Where is the fuel filter on these cars? I can not see it, even with a flashlight. I want to change the filter as this could be my problem Thanks for your comment The fuel filter is in the rear. How to Replace the Fuel Filter Quote Link to comment Share on other sites More sharing options...
Lexus_DK Posted September 24, 2017 Share Posted September 24, 2017 Start by Cleaning your maf sensor with maf cleaner. Clean your throttle body. Quote Link to comment Share on other sites More sharing options...
Exhaustgases Posted September 24, 2017 Share Posted September 24, 2017 Absolutely DO NOT CLEAN THE AIR METER. You will ruin it. $700. for a new one if you can find it. Quote Link to comment Share on other sites More sharing options...
vissine Posted September 24, 2017 Share Posted September 24, 2017 8 hours ago, Lexus_DK said: Start by Cleaning your maf sensor with maf cleaner. Clean your throttle body. I read somewhere that you can clean MAF of 98 model and later but not on 97 and older models. Quote Link to comment Share on other sites More sharing options...
