jorg Posted March 20, 2017 Share Posted March 20, 2017 Has anyone done a brake job on a '08 GS 350 AWD?? Any guidance would be appreciated Quote Link to comment Share on other sites More sharing options...
jorg Posted February 16, 2018 Author Share Posted February 16, 2018 Hi- I wanted to check back, has anyone done a brake job on an '08 GS 350 AWD?? Thxs Quote Link to comment Share on other sites More sharing options...
austinkwebb Posted March 4, 2018 Share Posted March 4, 2018 Like any other operation if you've worked with other cars with calipers. Open brake reservoir and watch level, push in pistons, caliper the rotor thickness and brake lathe if needed, apply non squeak grease to backing plates, install new clips if needed, install pads, reinstall caliper. Nothing special, and no frills. Quote Link to comment Share on other sites More sharing options...
jorg Posted March 5, 2018 Author Share Posted March 5, 2018 Thank you...that's what I was hoping. My friend has a Mercedes and before you remove the calipers you need to discount a fuse to an electric actuator so the calipers won't close on your fingers as you are taking them off. As far as you know nothing like that on this car?? Quote Link to comment Share on other sites More sharing options...
austinkwebb Posted March 5, 2018 Share Posted March 5, 2018 No, nothing special. Just push in the pistons in the calipers and monitor that brake fluid level at the front because pushing them back in will raise the level of the fluid and that stuff WILL eat your paint right off the car. Do not let any fluid out without sucking it out with like a turkey baster right into a container cleanly. Quote Link to comment Share on other sites More sharing options...
jorg Posted March 5, 2018 Author Share Posted March 5, 2018 Thank you Quote Link to comment Share on other sites More sharing options...
