P0773 - Shift Solenoid E
vissine
1 hour ago, Exhaustgases said:
You drain and remove the transmission pan, and its found on the valve body.
Thanks Exhaustgases for your reply. The ECU was bad. I swapped it with a spare that I bought a few years back.The code went away.
