Roger
Rogersoldls
There are 2 bolts in the front and 2 in the back of the seat that connect it to the floor. They are covered by plastic trim which you just pop off, move the seat forward and backward to remove bolts. You also have to remove 1 bolt that connects the seatbelt to the seat, you also have to pop out the plastic trim to gain access but it's obvious. Now raise the front of the seat and then disconnect the battery since you will be unplugging the airbag and power seat connectors. You don't want to accidentally deploy the airbag so wait a couple of minutes after disconnecting the battery before unplugging the connector.
