disconnecting electrical plugs from sockets fuel injectors
yovaken
! would like to disconnect the fuel injector electrical plugs from the injectors without damaging every one I come into contact with!  What's the combination to that safe?  Where to get a tool to separate those plugs?
The insulation is so brittle it's going to probably crack for sure. I used a pair of needle nose pliers and was very gentle when changing my starter. I think I still damaged one though.
And in most cases if the little latching clip breaks you can wrap a small wire tie around the receiving plug and then another between the 2 wires and into the first tie then tighten the first then the second one.  Its either that or try to purchase new connectors and the hassle of removing the contacts to transplant to the new part, there are special tools for that.
