92luxasls400 Posted August 26, 2016 Share Posted August 26, 2016 Problems with it running when driving it help please Quote Link to comment Share on other sites More sharing options...
92Lexus ls400 Posted August 26, 2016 Share Posted August 26, 2016 Car runs rough when driving and wants to die when ur at a light but if u let sit for a day and start it runs fine tell u drive it it spudders and dies when it runs wat could this be thank in advance Quote Link to comment Share on other sites More sharing options...
sha4000 Posted August 27, 2016 Share Posted August 27, 2016 Threads merged. Is your check engine light on? If so this is how you pull the codes. http://www.lexls.com/tutorials/intro/codereading.html Quote Link to comment Share on other sites More sharing options...
Exhaustgases Posted August 28, 2016 Share Posted August 28, 2016 That is a very common problem on these cars and no real resolution for the problem. It could be anything from the gas cap not venting, to the Idle air control valve leaking and or not working correctly. Also O2 sensors and egr. If you do get it sorted out please post here what it was. Oh and the fuel pump resistor can be a problem. Since the controls are electric always look for corroded connections and bad grounds too. Like I say many have had this problem with their cars and no solid resolutions yet. I have a 90 that does it too, its on my list to work on just too busy with other stuff. For more ideas there is also the ECU capacitor issue that can cause problems too. Quote Link to comment Share on other sites More sharing options...
