ptsagcy Posted April 27, 2004 Share Posted April 27, 2004 I would like to buy and install the 03 upgrade. Where is the unit located and how difficult is it to swap the DVD? Thanks Quote Link to comment Share on other sites More sharing options...
RXlover Posted April 28, 2004 Share Posted April 28, 2004 In my 2001, the DVD player is located near the spare tire. If you lift the carpet and look to the right, behind the tire jack you will see the DVD player. You will probably need to remove the jack to eject the disk. With the key "on" there is a slide button cover that says "open". I think there is an eject button under the cover which is pressed, but sliding the cover may be all that is required to eject the disk. There are two 2003 DVD upgrade disks for sale on E-bay. Quote Link to comment Share on other sites More sharing options...
shoeworx Posted May 1, 2004 Share Posted May 1, 2004 I also have a question about the DVD navigation system. I 'm not sure which one I have. I have a 2001 RX300 with original navigation DVD. I purchased the DATA ver 03.1 on ebay because the dealer price was outrageous, and now I can't seem to figure out how to install it or if this is the most current one. I've looked beside the spare and see where it is suppose to go but I don't see a way to open it. Any suggestions? Quote Link to comment Share on other sites More sharing options...
ptsagcy Posted May 2, 2004 Author Share Posted May 2, 2004 Found it. Thanks. See above reply BY RXlover, it is correct. Once you slide the tab, it exposes an eject button. Simply puch the button and the DVD pops out. NOTE IGNITION MUST BE IN THE ON POSITION SO THE SYSTEM IS TURNED ON TO EJECT THE DVD. Quote Link to comment Share on other sites More sharing options...
fabio.soto Posted June 1, 2004 Share Posted June 1, 2004 shoeworx - did you ever install your 03 version that you purchased from eBay? how did that go? Quote Link to comment Share on other sites More sharing options...
ptsagcy Posted June 2, 2004 Author Share Posted June 2, 2004 I did buy it and install it. Piece of cake once you find the darn thing. See my post above and RXlover's for instructions. Quote Link to comment Share on other sites More sharing options...
