I just had my battery replaced and was following the manuel to reset the windows.  I did the driver window with no issue.  I tried the other 3 door windows and it was not working on the driver arm rest OR on each individual door control.  Not one of the other windows work at all so following the manual instructions did not help.  Any suggestions out there??
Thanks!  I disconnected the battery again and redid everything.  I did make sure the key was in the "On" position only.  I read that somewhere and it worked.  I think key placement was probably the trick.
  • 1 year later...
I had just the same issue when I cleaned the posts of my accessory battery,  I ended up manually lowering and raising up all of the windows at each door before the driver's control panel would work on auto for all of the windows.
