Suspension Sensor Adjustment
drdfblackm
Ok I have a 2006 GX470 and the driver sensor was bad...completely corroded to death. Ok I installed new sensor, but I feel either the left or right or both need to be adjusted. The rear does go up and down now. but I feel that "Normal" is too high in the rear and "Low" does not drop the suspension all the way to the bump stops. I removed the right side to look and see if it was bad (corroded on the inside) and it looked fine. So I am looking for page 25-3 of the shop manual that tells how to properly adjust the sensors.
Any help would be greatly appreciated.
