Calling all RX350 2010 to 2015 owners! Has anyone experience having left your Vehicle for a couple of weeks with out starting, to find out the battery is dead and need a boost I've had the battery replace twice and it still does the same thing the dealer tells me that I don't drive the vehicle enough :o I appreciate all comments thank you.
One of 2 things. Could be some small electrical drain, unlikely. Or most likely is a failing battery. Have it load tested, not just voltage check. That is how batteries die in normal life.
