Hunted Posted June 16, 2015 Share Posted June 16, 2015 Hi All, This topic may have been brought up and I have researched but I never found a supplier of adjustable suspension components (like camber, toe, etc) to address my alignment issue. Here is the deal: I purchased 19" staggered MMR HR3's and a set of Tanabe springs with a drop of only 1.0"F & 0.8"R w/ only 5% increase in spring rate as I wanted as stock as possible with marginal drop, because I really don't care id it looks like it is sitting on the ground, I actually want to drive this car, but improve its handeling somewhat and keep the good ride. The guaranteed fitment advertized by the wheel reseller turned out to be BS because I did have to replace all the stock studs with longer ones and the cut them slightly to fit the wheels mounting depth, but all went accordingly. When I droped it off the the alignment shop, they told me they could only adjust the stock (camber and toe) to a figure that was probably good enough. Said he set up for stability but was still a compromise. But good enough is apparently not great because once and a while durring an on ramp full throttle romp, suddenly the front feels like it gets the shakes and really dosen' t go away with a tap on the brakes or swerving, nothing until I stop. The car has sometimes acted like it has a bad tire balance (a little bit) but I could almost live with this being that the tires and wheels are a lot heaver than stock set up. But this sudden front end (shopping cart) osolation I can not tolorate and is a bit scarry when I am into the the throttle. Any ideas? Do you think I need adjustable suspension components when all that I did was drop the car an inch? And if so, where would I buy adjustable suspension components for a 2002 LS430? Thanks, all ideas welcome Quote Link to comment Share on other sites More sharing options...
Hunted Posted July 2, 2015 Author Share Posted July 2, 2015 Wow so many responses! I can't keep up Quote Link to comment Share on other sites More sharing options...
Hunted Posted July 2, 2015 Author Share Posted July 2, 2015 Anyone own a Lexus with custom 19s Quote Link to comment Share on other sites More sharing options...
Hunted Posted July 2, 2015 Author Share Posted July 2, 2015 Think I will buy a Beemer. Seems more people interested in these Quote Link to comment Share on other sites More sharing options...
