jb hammer Posted February 25, 2015 Share Posted February 25, 2015 I'm interested in knowing the reasonable towing weight for a 2012 GX 460. I know the weight limit is 6500#, but I've been told that it will wear out the brakes and transmission if you try to pull the limit. I already replaced the trans on an RX300 by towing and 2000# tent trailer. A mechanic told me that you should figure about 1/2 the listed weight, if you don't want to be holding up traffic and destroying your rig. Any insights would be appreciated. thanks, Quote Link to comment Share on other sites More sharing options...
lsrock Posted October 22, 2016 Share Posted October 22, 2016 1/2 the listed weight is a good recommendation. Tow at full rating for short, level & smooth distances. I tow a 3500 lb trailer with electric brakes no problem. Also recommend a weight distribution hitch & stabilizer. Husky 31330 Lightweight Pin Trunnion Bar Weight Distribution Hitch - 500 lb. Tongue Weight Capacity. StowAway Hitch Tightener, Anti-Rattle Stabilizer for 2 Inch and 1.25 Inch Hitches Quote Link to comment Share on other sites More sharing options...
