Nardos_World Posted January 10, 2015 Share Posted January 10, 2015 I have a 2013 GS350. Approximately a month ago I turned the volume past 30 and the system went mute. No music plays and the touch pad doesn't make noise when you select anything. I have to restart the car for everything to function properly. Anything under volume 30 plays fine. Any ideas? Thank you Quote Link to comment Share on other sites More sharing options...
pj8708 Posted January 11, 2015 Share Posted January 11, 2015 I have a 2013 GS350. Approximately a month ago I turned the volume past 30 and the system went mute. No music plays and the touch pad doesn't make noise when you select anything. I have to restart the car for everything to function properly. Anything under volume 30 plays fine. Any ideas? Thank you Hi Nardos and welcome to the Club. I've never heard of this problem before, so I'm not sure I can help you much. It sounds like the head-unit and or amp may have tripped a maximum output limiter. This could act like a safety net in that by limiting the loudness of the head-unit it protects your components from "frying". No blown speakers. However, I'm perplexed about your unit's working up until the volume hits 30, then drops out from then on. This is the point where you take your ES to your dealer and let them fix it under warranty. Generally speaking, most dealers will just remove the problem components and put a new head unit or amp in or whatever the case calls for. After you've talked with your dealer, come back and let us know what you found out. Paul Quote Link to comment Share on other sites More sharing options...
Nardos_World Posted January 11, 2015 Author Share Posted January 11, 2015 Paul I dropped the car off at service yesterday. The advisors never heard of the issue either. Good thing I could replicate it. I'll update once my car is done. Bernard Quote Link to comment Share on other sites More sharing options...
Nardos_World Posted January 22, 2015 Author Share Posted January 22, 2015 I have a 2013 GS350. Approximately a month ago I turned the volume past 30 and the system went mute. No music plays and the touch pad doesn't make noise when you select anything. I have to restart the car for everything to function properly. Anything under volume 30 plays fine. Any ideas? Thank you Hi Nardos and welcome to the Club. I've never heard of this problem before, so I'm not sure I can help you much. It sounds like the head-unit and or amp may have tripped a maximum output limiter. This could act like a safety net in that by limiting the loudness of the head-unit it protects your components from "frying". No blown speakers. However, I'm perplexed about your unit's working up until the volume hits 30, then drops out from then on. This is the point where you take your ES to your dealer and let them fix it under warranty. Generally speaking, most dealers will just remove the problem components and put a new head unit or amp in or whatever the case calls for. After you've talked with your dealer, come back and let us know what you found out. Paul Good Afternoon I just got my car back today and it was a open circuit which caused the amp and sub to short. Lexus replaced that and a door speaker under warranty. Quote Link to comment Share on other sites More sharing options...
