Michael LS 400 owner Posted January 5, 2015 Share Posted January 5, 2015 was working then smelled smoke then not working. replaced motor and other than having to splice wires, it went well. blower still not working. there are relays on fuse panel that are not labeled also on engine fender. HELP Quote Link to comment Share on other sites More sharing options...
Vegan Posted January 5, 2015 Share Posted January 5, 2015 Yes, Landar has definitely been a guiding light/sherpa in this foreign land. Quote Link to comment Share on other sites More sharing options...
landar Posted January 6, 2015 Share Posted January 6, 2015 Welcome, Michael. Take a deep breath...feel better? Doesn't work for me either! ^_^ Lets try to recap your experience. You smell smoke and the blower motor is not working. So you replace the motor. Is that about right? I do not like the sounds of wire splicing because you should just have to remove a connector and plug in the new motor. No splicing required. This is going to take some patience and a good amount of sleuthing to get to the root cause. Are you ready? Cuz I am not. About the closest diagrams that I have are from a 92 LS400 and I am hoping it did not change too much in 95. But it might have. Let's just say that there are a lot more things to go wrong than the motor and maybe the burning smell was not the motor. So, we start with the motor. Will the old motor run if you momentarily connect the +(pin 2) to pos. 12v and - (pin 1) to ground? Quote Link to comment Share on other sites More sharing options...
