Daytime Running Lights
JDOwen2, DRL is supposed to be visible during the day so HID solution will not be a good idea since HID is closer to the sunlight. You should disable the DRL or may be try using some of the colored bulb but may not pass the inspection because it will affect your high beam light. DRL on ‘98 and up are lowered output of the high beam light so not much you can do unless you change the output to another source.
