arabian Posted April 8, 2004 Share Posted April 8, 2004 Hey Gang, Newbie here, I'm going to attempt to change my brake pads on a 92 SC 400. I checked out other threads and can't get my question answered. So far I've gathered I need to remove the center portion of the caliper assy. The thing is, other threads have said that there are 2 bolts holding the center portion I'm supposed to remove. On mine, there are 4 bolts (allen wrench style). 2 bolts holding caliper assy. 2 bolts above the 2 I just mentioned 4 bolts in the center (allen wrench style) Also, since my pads are pretty worn, and the new pads are a lot thicker, how do I get them to fit in? How do I push the pistons back to make room for the new pads? Any help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
AWJ Posted April 8, 2004 Share Posted April 8, 2004 It should be just two 12 or 14 mm bolts on the floating portion. You only need to remove 1 and flip it up. To get the pisons back, you should open the bleeder slightly and push back on the old pads until they retract a little. Then close the bleeder asap. Try not to get air back in the line. Good luck. I'll try and snap a pic of my old ones in the garage. Quote Link to comment Share on other sites More sharing options...
arabian Posted April 8, 2004 Author Share Posted April 8, 2004 The 2 bolts, not the ones that hold the caliper assy in place, have a rubber boot of some sort below it. Are you refering to those bolts being removed? Pics would be great. Much appreciated. Quote Link to comment Share on other sites More sharing options...
Bubbles Posted April 9, 2004 Share Posted April 9, 2004 To change the brake pads, you'll need to take off the bolt with the rubber boot along the same axis. Just take the top bolt off and loosen the bottom one so you can pivot the brake pads out. This picture is on an sc300 and it's rotor and possibly the caliper is smaller. The bolt right under the " I " is the one. DISREGARD the arrows, that will only lead you to 1.5 pounds of dirt! To fit the thicker brake pads you can get a c-clamp and press the pistons in. I doubt many people have a c-clamp. However, if you do that the brake fluid level in the reservoir will rise, so you'll have to suck some of that out (just don't let any dirt drop in. Quote Link to comment Share on other sites More sharing options...
arabian Posted April 9, 2004 Author Share Posted April 9, 2004 Thanks much Bubbles. The pic helps out more than you can imagine. Also, on a completely different topic, where can I go and get a new motor and cable for the power windows... I'm assuming they all come together since the cable runs through the motor. Should I check out local junkyards or can I get it somewhere else? Quote Link to comment Share on other sites More sharing options...
arabian Posted April 9, 2004 Author Share Posted April 9, 2004 O.K. New problem. I tried to remove the 2 bolts, but they won't budge. I practically crapped my pants trying to have the bolt move a mm. Any suggestions on how to get the damn bolt off? Quote Link to comment Share on other sites More sharing options...
Bubbles Posted April 9, 2004 Share Posted April 9, 2004 Oh yeah, that happened to me too. Such a pain... The reason why it was so hard for me was because I couldn't find a position to fit my torque wrench on it (I use my torque wrench to take off those super tight bolts because the bar is longer than a combination wrench). So what I did was jack the car up higher and I finally got the torque wrench in place and I used my leg to push on the wrench. Quote Link to comment Share on other sites More sharing options...
