Marc in TO Posted August 8, 2014 Share Posted August 8, 2014 I have the same problem on a recently purchased 2005 ES330 that many have posted about. The rear windows go up , hit the rubber and reverse back down. Several people have suggested opening the door, putting the window down at the same time, slam the door shut. I have tried this on both rear doors, and either I am not slamming it hard enough or this particular fix does not work for my car (and I am slamming it pretty hard!). Does anyone know how to completely de-activate the sensor? Is there a fuse I can remove? Or can I physically remove the sensor in any way? Any suggestions would be appreciated. I have managed to get the windows up by using the window lock on the driver's panel, but it's a pain to do it repeatedly every time someone opens the rear window! Thanks! Quote Link to comment Share on other sites More sharing options...
gooden Posted August 8, 2014 Share Posted August 8, 2014 Marc, I sat in drivers seat and held button down as my daughter slammed the door, on the 4th attempt the window went down , window has worked normal since then. Knock on wood. I assume going up is the same sequence. Rob 1 Quote Link to comment Share on other sites More sharing options...
Marc in TO Posted August 8, 2014 Author Share Posted August 8, 2014 Thanks Rob. I'll give it another try from the driver's seat and see if that works. Quote Link to comment Share on other sites More sharing options...
