How To Test A/c Condenser Fan
bode
Hi,
Was told I have a bad condenser fan. I want to test it to see if it works. How do I bypass relays and/or pressure switch to see if high speed works. Don't know how to diagnose problem. High speed not working.
thanks for any help
Bode
CONDENSER FAN
ON–VEHICLE INSPECTION
1. INSPECT CONDENSER FAN OPERATION
Check the fan operation at each temperature and refrigerant
pressure, as shown in the chart below.
Engine coolant and refrigerant condition A/C switch Magnetic clutch Fan motor speed
83 °C (181 °F) or below OFF or ON OFF OFF
90 °C (194 °F) or above OFF or ON OFF or ON High
83 °C (181 °F) or below and the refrigerant pressure is
approx. 1,520 kPa (15.5 kg/cm2, 220 psi) or above
ON ON Low
If operation is not as specified, proceed next inspection.
2. INSPECT FAN MOTOR OPERATION
(a) Disconnect the connector.
( B) Connect the battery and ammeter to fan motor connector,
as shown in the illustration.
© Check the fan rotates smoothly and check the reading on
ammeter.
Specified amperage: 4.2 – 4.4 A
If operation is not as specified, replace the fan motor.
If operation is as specified, check the fan relay, pressure switch
and pressure switch.
post-5365-0-72771200-1403112294_thumb.jp
