Cheraig Posted June 2, 2014 Share Posted June 2, 2014 I have a 2005 RX330 with 156,000 miles on it. Just about a week ago the ABS, BRAKE, VSC, lights come on steady and the LOW TIRE light is flashing. These come on and then all go off. Keep driving they come on again and off and back on. I found out that the rear wheel bearing needs to be replaced. Could these be related? This all started after I had the vehicle go through the State Emissions Test at a local testing site. Any ideas as to what is causing this? Quote Link to comment Share on other sites More sharing options...
RX400h Posted June 3, 2014 Share Posted June 3, 2014 Have you checked the pressure in each tire? It could m be that an underinflated tire can adversely affect VSC and ABS. Quote Link to comment Share on other sites More sharing options...
