Ac Compressor
pierce1
I picked up my car today (92 ls 400 93,000 miles)after having the timing belt, drive belt, idler pulley, transmission filer kit etc., and water pump installed. Noted on the ticket was that my power steering pump at the resorvior was leaking, i just put a new pump on last march, could it be it need a new seal around the resorvior? Also noted on the ticket that my "ac compressor was leaking oil???" either it is or it isn't. Is there any symptons of ac compressor oil leaking and if so can it be repaired or does it have to be replaced? My ac is working fine.
Also what type of buldb (#) do i need for the fog light, it was posted on this site but I cannot find it, I know it was a wagner that cost $25.00 since the H3 will not work.
Thanks
Thanks
I called a import service center and a guy there told me if the oil was leaking so was the freon and said I needed a new ac compressor. Thanks for the heads up.
Definitely cheaper than a new ac compressor at $600+.
