1995 Ls400
tarasi57
I,ve had the battery, starter and alternator checked....All good, yet when it sometimes clicks as if there is aproblem with the battery or starter. It doesn't do it all the time, but frequently. The battery terminals are clean. Actually, I had a new alernator put on, so that shouldn't be the problem. Is there something else I should be looking for?
Thanks,
Paul
FIrst off, you need to explain the problem that you are having. When trying to help from a distance, every little detail counts. So, I gather that your engine does not always crank and do you get a single 'click' or a series of clicks?
