tarasi57 Posted October 15, 2013 Share Posted October 15, 2013 I,ve had the battery, starter and alternator checked....All good, yet when it sometimes clicks as if there is aproblem with the battery or starter. It doesn't do it all the time, but frequently. The battery terminals are clean. Actually, I had a new alernator put on, so that shouldn't be the problem. Is there something else I should be looking for? Thanks, Paul Quote Link to comment Share on other sites More sharing options...
billydpowell Posted October 15, 2013 Share Posted October 15, 2013 YES!! It will reach the point when it just clicks.... You need to replace the solenoid kit. your old one will look like this.. Quote Link to comment Share on other sites More sharing options...
landar Posted October 15, 2013 Share Posted October 15, 2013 FIrst off, you need to explain the problem that you are having. When trying to help from a distance, every little detail counts. So, I gather that your engine does not always crank and do you get a single 'click' or a series of clicks? Quote Link to comment Share on other sites More sharing options...
