tcrespi Posted September 26, 2013 Share Posted September 26, 2013 When replacing the 1616 is it necessary to remove the 3 screws on the inner unit of the key or is there some way to do so without removing 3 screws. We own 3 Lexus models and have 3 totally different keys and battery set ups! Any help that includes a diagram, instructions, photos or perhaps a U-Tube link would be greatly appreciated. Tried all above before asking w/o success. Thank you. Quote Link to comment Share on other sites More sharing options...
zilch Posted September 27, 2013 Share Posted September 27, 2013 I just replaced batteries in both keys and it was pretty easy to remove the screws with a quality philips "0" bit. I don't see any way that I could have changed the battery without removing the screws. The single screw holding the key body to the internals did have little Loctite on it, but the two inside on the battery cover came out real easy. They are small, but it took 5 minutes to do. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted September 28, 2013 Share Posted September 28, 2013 Stores like Batteries Plus where I live change the key batteries at no charge when I buy new ones and have the correct tiny screwdrivers to do it. Quote Link to comment Share on other sites More sharing options...
