I have a traction or skid light on my dash.i got an alignment done to c if the steering angle sensor needed to b adjusted . Light is still on? Txs
Hi Garys and welcome to the Lexus Owners Club.
First, you talk about your traction or skid light. I think tou mean slip light and or tranction light. They really are two seperate things. In your owners manuals you will find a discription of what each of these system do. Neither one of them have any thing to do with the alignment of the wheels.
The slip indicator light/traction control light can mean;
Malfunction of the VCS (Vehicle Stability Control) system
Malfunction of the Traction Control System
This light will flash when these systems are operating. I can't rember clearly if the 2010ES has a button for turning the traction control on and off.
Txs will check. Never got an owners manual for the Veichle. Just got the car a month ago
I just had an issue with my ES 350 the check engine light and the vsc light came on.I took the car to the shop and they put a test on the computer and found that the coil wire on # 6 cyclinder was defective. After it was replaced all the lights went out and everything is working well.
