My 460 has a periodic steering vibration after it has set for a period of time. I was told by dealer it was possibly the Bridgestone tires developing a flat spot from not being driven. It sometimes occurs after one hour and sometimes not until after setting for 3-5 days. I have now put Michelin tires on and same thing is happening. I have continually taken it back for balancing and rotation and it still continues to have the periodic vibration. I now have over 50,000 miles on it and still no answer from Lexus dealer or tire dealer.
Anyone else had this problem or have a suggestion?
Mine also will do this sometimes but normally after driving for a short while it seems to go away. I try to keep a eye on my air pressure and I run a little lower PSI than reccomended.
  • 1 year later...
If there is dirt on the INSIDE of your wheels, it will often fall and settle on one side of the wheel. Then, when you go for a drive, the wheel will be out of balance. Look on the inside of the wheel and make sure it is clean....all the way around.
