What Plug/sensor Is This
superman8589
Hey, my name is robbie new to the form I have posted another post concerning my car not turning on after starter build. I came across this plug it seems as if it was screwed in but I have no idea where it goes what it is.. previous owner mechanic must of unhooked it...
Found it in driver side under v bank.
Hi,
If it is a white plug, and if it is suspiciously close to the driver side ignition coil (and it looks like it is!), I would hazard a guess that it bolts onto a bracket very near the coil. I did a writeup somewhere here on replacing the driver side ignition coil - if you can find it, it will explain where the plug goes and how to put it there.
Hope this helps.
  • 3 weeks later...
