hey guys i have a 93 lexus gs300 and my batt recently went dead and i had it jumped and the dash lighst didnt come back on and i dont have a radio and now power to my windows and there is no tail lights either i am a collage student and need my car fixed asap so if anyone can help i would be greatful thanks
Check all the fuses
if you had the car jumped then you could have done damage if you did not jump it correctly.
Get the fusues checked first and then let us know what you find
ok this is what happened i had a bad cell in bat and it kept dieing and i changed the batt to one that was 20 or 40 amps lower and instaled it and when we hooked it up i got nothing but it would start so then i put the old batt back in and got it started they all came back on then i put the new one in but i went out to eat then left and all the lights went off again so i piulled over and put it into park now it wont move all fuses are fine and i also pulled the altanator out today and had it checked and it was fine so i decided to pill the ecu fuse and when i did car shut off like i exspected and i waited a few mins and put back in and all the lights worked! i was happy but.... i did noticethat the batt light was on so i let run for a bit and then turned it off and tried again then got the same thing no lights what the heck guys can anyone help???
  • 3 months later...
I figured it out and yes my fuse panal had a hole burnt threw the contact points thanks for the help
  • 3 weeks later...
