Steering Wheel Tilt
fire lexus
Dear freinds
i had disconnect the battary for my ls400 to set the the throttle .
but After connecting the terminal the steering wheel didnt does down (as usual when you insurt the key ) and the steering wheel didnt goes up and down , only to the front and back
any one had encounter this problem before
Best Regards
You will probably also find the memory seat doesn't work either, the seat and the steering wheel need to be reset. Adjust both the seat position and the steering wheel to your required positions, then on the driver's door panel press and hold SET until you hit the bleep then press either memory 1 or 2 to store the positions.
