Oil Control Valve
tony_lexus
Hi All,
I have ls400 1999 and it has 130K miles on it. Timing belt, water pump changed at 90K.
Today I got these codes:
P1354-VVT System Malfunction Bank 2
P0302-Cylinder 2 Misfire
P0304 Cylinder 4 Misfire
P0306-Cylinder 6 misfire
Questions: which side is bank 2? On the passenger side or the driver side? I can see there are 2 OCVs. One on each side. As test, I remove the plug to the OCV on the driver side, I got code P1656 in addition to the P1354.
Does this mean bank2 is on the passenger side.
I also try to remove the OCV but it seems it does not want to move it. I can rotate it freely but not coming out. How do I remove it.. I dont want to put any force before I find out the proper way. Please help. Any suggestion is appreciated.
Thanks a lot
Tony
on mine, I removed the connector and took the bolt out, and I was able to slide the ocv out of the chamber, cleaned both and put it back in and no more problem... that was a year ago. during that time I wanted to do the passenger side and it required removal of all the items that are in the way... A lot more work. but worthwhile.
post-5365-0-43821100-1357741964_thumb.jp
  • Like 1
