CRX_Fan Posted December 30, 2012 Share Posted December 30, 2012 Hi at all!! I am looking for a member who can measure me something! For a conversion in a Celica, I need the Length and Height from the power mirror switch button of the Lexus ES. Btw. many other Lexus from the years have build the same switch too, I saw. Here is a pic of the switch and the dimensions I need: I'd be happy if someone can measure it for me! Best regards and happy new year! Ben Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted December 30, 2012 Share Posted December 30, 2012 According to a parts number website I use - see attached - my 2000 LS400 appears to use the same mirror switch as the 2011 ES350. The sides of the switch are somewhat rounded. Measured with calipers, the switch is about 31mm tall by 34mm wide at the tallest/widest points. These may not be exact measurements but are probably within 1mm of actual. What are you trying to do? There are many versions of the mirror switch in vehicles made by Toyota. Quote Link to comment Share on other sites More sharing options...
CRX_Fan Posted December 30, 2012 Author Share Posted December 30, 2012 Hi Dark Helmet :D and Thank you for the dimensions! :) I will install this switch in a Celica ZZT23, because this Lexus switch is the only, which is illuminated! ^_^ And because I now know the rough dimensions, I can buy this switch, and can let me build a suitable cover for the switch! Perfect! So thats the reason I needed the approximate dimensions of the switch! I like those little Gimmicks. And the Celica and the most other Toyotas dont have the power mirror switch lighted! So again...thank you very much and have a great new year! Ben Quote Link to comment Share on other sites More sharing options...
