Vsc In 2001 Rx 300
DebbieG
Anyone know what is involved in cleaning the sensors associated with the VSC---it engages for no reason and that seems to be the advice I am getting--only stops if ABS is disconnected but I do not want to disconnect the ABS permanently
Try to diagnose the problem first. If it engages while slowly stopping ( ABS) cycle then it is possible that you have a broken tone ring at one of the rear drive axle shafts.with a high mileage car you will probably never get the sensors out to clean them, they rust into the knuckle . Sensor failure is very rare.
