An anti-theft process is a great selection that comes stock or regular on some newer models of automobiles. The process prevents your automobile from being stolen and will, in some situations, lock the engine when it senses a threat. That causes a considerable problem at times since it could possibly lock itself for no cause which means that you just can??t begin your car. If this occurs, you are going to should turn off the anti-theft system by tricking the car into thinking the threat has passed.
Instructions
Look on your dashboard for a light that indicates an anti-theft program. On most cars it really should say theft system underneath a small light. This shows that you do have an anti-theft method in your vehicle and that it's presently working.
2
Check the wiring beneath the auto to make positive the wires are intact and that they aren't missing or loose. You are able to learn what wires go to your anti-theft technique by looking in the owner's manual that came along with your car or truck, or by borrowing a manual in the library.
3
Look at your battery to generate confident it's working. If the battery is dead, your car will make a soft whirling sound or the engine will only click any time you attempt and turn it over. Have the vehicle jump began if the battery is dead.
4
Put your crucial in the ignition and twist your hand forward. You wish the interior lights and radio to come on, but not the engine itself. In some instances you could possibly really need to turn the important backwards to perform this, but it is determined by the make and model of the car.
5
Wait a minimum of ten minutes ahead of you take away the essential. This does place some pressure around the battery so you might want to be certain the battery is operating prior to you do that. Soon after 10 or 15 minutes, the anti-theft process on your car will shut itself off and you??ll see the light on your dashboard turn off. As soon as this happens, you can very easily get started your automobile.
Edited by SW03ES
Remove spam link
  • 1 month later...
I've read this a couple of times, still not sure what it's about. If you're talking about a Lexus RX, can't imagine there's anti-theft wiring exposed on the underside of the car. I'll have to check the manual to figure out if I have the key(fob) when I, the owner, would have to crawl under the car to trick the security system.
  • 2 months later...
