Hello... I would like to ask if anyone has idea how to remove a paper that went inside the hatch of the GX470 center cup holder. This caused the cup holder cover to not open completely rendering the cup holders unusable. Any help solving this problem is appreciated. Attached is a picture and an arrow pointing to the problem area. The cover does not fully open now because there is a paper blocking the space.
post-110853-0-19137700-1349842896_thumb.
Sincerely,
Randy
I believe a previous member has coins drop in that same spot in their GX470 before. You will have to remove the console covers in order to get that stuck paper. Try searching the GX forum that topic should be somewhere here.
The cup holder pops out if you pull up on it. Open the lid, grab it with both hands, rock it gently, and pull upward. However, denslexusGX470 is right about the center console compartment. If something slid down the door opening of it, there's a post elsewhere on the forum regarding removal of the entire center console assembly.
