Spamkiller Posted September 14, 2012 Share Posted September 14, 2012 Lately, my horn sometimes does not work. When the horn does not work the mode and up/down button does not work. The volume and phone buttons work. But, it just starts working again for a while, then stops again. Sounds like a loose or worn connection. Any clues on where to look? Thanks. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted September 14, 2012 Share Posted September 14, 2012 I don't know your SC has the same design, but I had to have a new horn pad/air bag assembly recently when my horn on my 00 LS started working intermittently - it wasn't something my mechanic could take apart and repair. Fortunately the repair shop quickly found a used assembly in the same color. Total cost of the repair was about $750 which was a fraction of what it would have cost if they had used new parts. I guess you could take off the pad and check the connectors and wires. Be sure to disconnect the battery if you do that. Quote Link to comment Share on other sites More sharing options...
