samuel.wieler Posted August 22, 2012 Posted August 22, 2012 Hi there guys, My 1994 SC400 is having fuse problems. Here is the problem. When i start my car and it is hot out and i decide to turn on the a/c the climate control unit turnsw on then seconds later the fuse blows and the whole unti turns off. so i replaced the fuse and turned it on again the following night ( by this time is was cooler out ) and the a/c unit / climate control was left on. (because the fuse blew before) but surprisingly it didnt blow. the unit works perfectly fine and it blew cold air and hot air also every function works. what is causing the units fuse to blow when it is warm out? what can i do to fix this? thanks guys i appreciate any ideas or solutions 1
Steve Posted August 23, 2012 Posted August 23, 2012 Hi and welcome to the Lexus Owners Club I am wondering if the AC unit is faulty. How many times has the fuse blown and do you have the correct amp fuse plugged in? 1
1JZPWRD Posted October 21, 2012 Posted October 21, 2012 Check to see if something has fell down in the cig. lighter holder like a coin or something. This will cause the climate control to not work and the fuse to blow. Check that first... 1
