Rear Wheel Noise
BlackLex
Could be a bad wheel bearing. if it makes more noise as you turn one way over the other that would tend to confirm it (loading and unloading bearing).
Could be sticky caliper pistons or caliper slide pin binding not allowing pads to release from rotor. Is rotor hot after a drive even when braking is minimal (don't touch with your hand rotors go up to 800 degrees under normal usage)?
