sule Posted July 11, 2012 Share Posted July 11, 2012 Hi, guys i changed my timing belt two days ago and after i finished started the car and it runs normal but the check engine light stayed on and i test it and is code 13 open cercuit rpm signal.so i drove the car and the RPM is not working normally. i will appreciate all the help i can get. thanks Quote Link to comment Share on other sites More sharing options...
sule Posted July 16, 2012 Author Share Posted July 16, 2012 Ok guys i found the solution and it was because i did not set the timing belt correctly one cam ok but one was off by half tooth.It was a good learning experience but the hard way.So just be advise when you doing this job make sure you set the belt wright or it will cost you another eight hours labor. Quote Link to comment Share on other sites More sharing options...
