oohryry1 Posted June 28, 2012 Share Posted June 28, 2012 Would like to know where the knock sensor is located on my vehicle so I can change them if the job isn't too difficult. Vehicle failed emissions, I replaced the throttle body which got rid of codes P1125, P1128, and P1780. Replaced O2 Sensor Bank 1 Sensor 1 which got rid of codes P0125 and P0135. Now I have P0325 Knock Sensor 1 Circuit Bank 1 Single Sensor code left along with P0753 Shift Solenoid A Electrical which I will do more research on for the transmission and post as a different topic unless someones gives references on this thread. Thanks for your help. P.S. can a bad spark plug cause the Knock Sensor code P0325 to come? I had it check out at a Toyota dealer and they gave me what I already knew which was the codes, so I went to work for myself on my vehicle and notice a plug wired was completely unscrewed and out of socket and I had a lot of leaks because I had several of my engine bolts so loose they were about to fall off. I wont speculated that someone did this but I don't know how my spark plug wire came out if I had them replaced at Lexus dealer during my timing belt change just over a year ago. Thanks for any help. Quote Link to comment Share on other sites More sharing options...
oohryry1 Posted June 28, 2012 Author Share Posted June 28, 2012 also I'm not new to the forum, I just can't locate my password because my old email account is deactivated. Quote Link to comment Share on other sites More sharing options...
