check engine light on,
search in google,check engine light on means one or more diagnostic trouble codes (DTC) are stored in the engine control module.
should i go to garage repair it or get a code scanner to clear the DTCs,
if i want to get a code scanner, which tool can do 2010 lexus rx,
have a chance look for the maxiscan jp701 and Professional Japanese Car u695,
which tool is better?
give me some suggesthions!
Hello. One of the best bits of advice I read here and use, not specific to your question, was to take your Lexus to a reliable toyota mechanic or dealership to get a less expensive analysis of what your problem may be.
At that point, you can also find out what kind of equipment one of these folks use & buy it or just take it to this place in the future.
Good luck. I notice you are in Idaho. I'm next door in WA.
best regards,
Jerry
have you bought it ? in my opininos MaxiScan JP701 is better for you !!! i want to know more details about a new release car key prog T300 plus ,you know about the tool????????chinasinoy
