I've been trying to research wheather or not the '98 ES300 wheel bearings need to have the knuckle removed (at least partially) or is that the year that has the 4 bolts accessible through the hub where you can just remove the hub and leave the steering knuckle attached ?
I think it's the type that needs to removed completely but I have to ask. =O)
