boosted01gs430 Posted February 14, 2012 Posted February 14, 2012 I have a 2001. Gs430 my driver side window switch doesn't work all the way. I can roll the driver side window up and down but will not work on any other windows have replaced the switch with a used one but same thing. And when useing the door unlock button on my key dose not un lock the driver side door but unlocks all the other doors ???????????
lenore Posted February 14, 2012 Posted February 14, 2012 Several different problems....The door (drivers) lock actuator is probably bad. Many threads on this on the RX300 forums.......As for the windows could have some broken wires in the wire harness going thru the door hinge area....That was a problem on a Camry that I just bought recently....Envolves taking door apart and pulling harness out to check for broken wires. At that same time you could replace the drivers door lock actuator....Good luck
boosted01gs430 Posted February 16, 2012 Author Posted February 16, 2012 Thank for the info found out I have to reset the window switch ..
