I just got a 2001 silversport that has the stock HIDs. The only problem is that the other lights are yellow in comparison like the fog, daytime and high beams. Any suggestions of bulbs that I can get (maybe led) that will give me a more consistent light color?
Unfortunately there aren't any direct replacement bulbs that will give you the consistent look you're talking about.
There isn't a single aftermarket halogen bulb that will give you the same color as the HID low beam. And there are white LED wedge bulbs that will replace the tiny parking light bulb, but the white will not match HID and there aren't many durable enough to last more than a month without burning out.
I've tried to find a setup exactly what you've described both on my old RX300 and on my current RX400h, but it simply doesn't exist :(
